dietoremain
Sooo the debate.. for my buddies 500HP+ truck is which one to get? I've heard good and bad about fluid... and several recommendations for ATI. tell me what ya'll think.
how would a fluidampr break lpop gears if its lighter than the stock damper? of course i dont have a 6oh but curious...
A good old tractor pulling friend of mine that builds and dynos lots of pulling tractor engines attempted running Fluidamprs for a while - they kept having main bearing issues that they couldn't cure no matter what they tried.... they swapped back to the ATI style damper and the main bearing problems went away with no real explanation as to why. This was of course several years ago and I don't know all the specifics other than I trusted the source. The 6.0 oil pumps seem to fall on those same lines - I've never hood a good reason as to why, but they seem to have a history of doing just that.
Strait from ATI...
Note the RPM range.
That really sounds like a harmonic frequency issue.
So in our rpm range, there isn't a significant difference in any of them? :shrug:
Don't really worry about it until you start spinning 6000 rpm regularly. :shrug:
You mean like the harmonics that damper is suppose to be cancelling it out? Because I specifically did not say that and wanted people to come to their own conclusions.
I don't see what else it could be. Sounds like the fluid in the damper is snake oil.
