Found Joe's IPR problem.
CSIPSD
Bend, OR
LOL... ***er.
Glad you started this thread... Uploading some videos then we can ask the why is this happening question...
Magnum PD
VA
LOL LOL
Would having the HPOP screen help? The one that Diesel site sells?
CSIPSD
Bend, OR
LOL LOL
I dont know...
Changed my oil last weekend, and when I was dumping the oil into the 1 gallon containers I saw some metalic stuff at the bottom. Not a ton, and some of it was plastic or dried gasket material, I'm not sure.
Did not have any issues before changing the oil other then needing an oil change.
Fast foward to this week, driving 200-250 miles a day right now...
Tuesday, truck dies pulling into the Wal-Mart parking lot in Monument (about 200 miles total for the day). IPR plugged, cranking and getting 300psi max at 60% duty cycle... Clean, replace and it fires right up.
Wednesday, Truck dies on I-25, right at the top of Monument hill just after exit 168 (about 200 miles for the day)... Same thing, IPR plugged. R&R and it fires right up.
Thursday, Truck dies on Hwy 115, about 30 miles from Penrose (about 230 miles for the day)... Same thing, R&R and it fires right up. Only thing differant is I was pissed and didnt get my wrench on all the way, bent my IPR rod. No problem, I carry a spare so I clean it and throw it in.
Yesterday, Truck dies on C-470 about 5 miles from I-25 (about 170 miles for the day)... R&R and it fires right up.
Each and every time I can see NOTHING in the IPR to cause this, clean it with brake clean, taking it apart as far as you can.
So the entire week I am thinking I have a motor getting ready to go, must be bearing material plugging the IPR. Thing is, truck is running fine otherwise, no weird noises, no weird vibrations, NOTHING.
Today I dumped the oil that has about 1400 miles on it, the bucket is settling right now and I will see whats in the bottom. I pulled the HPO Res and there was NOTHING in it, NOTHING other then a little sludge you would expect for 40k on the motor. No metal, no brass, no nothing.
Fired back up and took for a quick test drive and no issues (of course I am sure I will be pulling the IPR sometime monday...)
I'm thinking its a HPOP that is plugging the IPR, Sheding something, which then goes to the IPR and plugs it... Then the oil filter is cleaning up what is being cast off.
I am loading a couple videos of the motor running, it sounds fine but hell if I know... I have a line on a OBS motor, but I would rather not swap a motor if its not the issue, with a new baby on the way dropping $1500 is not what I want to do...
Magnum PD
VA
I would first try to get the ball peen hammer out of there first if it was me.
davey99ps
Waterford WI
I don't know if it would help you any Joe, but tomorrow I'm pulling my hpop off to swap my adrenaline on. If you need it, let me know. I can send it out to you to try, if it fixes the problem then you can give Mr some $ for it. Pm me if you wanna do that
CSIPSD
Bend, OR
Talyn
Thats a crazy sound, but your blow by is not even a concern.
I have far more than that. haha.
almost sounds like a lifter tick over the video.
does the video do the sound any justice?
Arisley
Arlington, Texas
I think you are being paranoid about the motor fixing to blow Joe. Which i can understand in your case. I think it is a HPOP eating itself also.
davey99ps
Waterford WI
My offer still stands, I can ship mine out on Monday if you need it. I know mines good, an would maybe help ya narrow down your problem. Good luck!
CSIPSD
Bend, OR
I think you are right.
When I changed the oil yesterday I was pouring it back into the 1 gallon containers looking for anything. Saw something huge in the bottom and got excited (thinking at least I have a direction...)... Picked it off the bottom and looked close...
It was a damn bug.LOL
The motor fires right up, runs good, slight miss but I believe that is an injector issue (cores have 400k or so on them).
I just dont see it being a motor issue.
Powerstroke Cowboy
Montana
CSIPSD
Bend, OR
I'm getting at the problem of something plugging the IPR every 200 miles or so...
Otherwise that slight miss in the motor has been there since it first fired 40k or more ago.
Motor runs good, no issues crusing down the road, gets up and scoots like it should.
Powerstroke Cowboy
Montana
This may be way of the wall. Would there be a chance that your HPOP line are deteriorating?? and causing junks to get lodged in the IPR??
