Front driveshaft bottoms out
DEEZUZ
NO PUKESTERS
NWI
Ok, so truck is lifted but my front shaft bottoms out. The inner slip joint bangs into the front u joint on full suspension compression. I took it down and sent it to be cut, welded, and balanced....
Anyone know why it's "too long".. doesn't make sense to me cause truck is lifted... Just wondering if someone installed the wrong shaft
if it is a 99-04 truck, and someone installed an 05+ front shaft, that typically occurs.
DEEZUZ
NO PUKESTERS
NWI
Ah, I'd have no idea unless there is a part# somewhere?
usually the tags are long gone with the part numbers. Take a collapsed measurement for me and i will measure a new 05+ one i have on the shelf and we can compare.
