FS: 18x12 Weld Dakar wheels w/ 38 MTZ's $850 cash in VA
mxtwo50r
18x12 Weld Dakar's 8x170mm
38x15.50x18 Mickey Thompson MTZ's
Tires a little under half tread. One has a bulge in one sidwall, been that way for quite some time.
Wheels will clean up well. One has 2 spots on the very inside edge that need to be repaired, nothing wrong with it structually, its the very edge next to the tire bead, not sure how it got messed up, but it was driven on for many years the way it sits. (This is NOT like the old 2 piece wheels where the centers crack or the weld cracks where the 2 pieces were welded together, these are 1 piece wheels and not prone to those problems) honestly, if I didnt mention it, you probably wouldn't see where it needs to be fixed, but I'm an honest seller. Local wheel shop quoted me 100 bucks to fix with a lifetime warranty. Otherwise they are in good shape, few blemishes on them but mainly just need a cleaning.
I paid 1000 for the set. Original plan was to sell the tires for 500 or so, have the one wheel fixed once the tires were off, and have a set of welds for under half what they normally sell for. I havent done anything with them so Im just going to pass the deal on to someone else.
850 FIRM. If you sell the tires for 400 (on the low side) you will have a set of 18x12 welds for 450 bucks, 550 after the one is repaired. They are selling for 1500+ on craigslist all day.
Located in Va beach VA
757 342 nine1nine5 text is best
Daryl@TDP
Chesapeake, VA
Good buddy of mine, good luck with sale man. I'll keep it in mind at the shop with any customers that may be looking something similar.
mxtwo50r
Backspacing is 4.5" or -51 if I am not mistaken. Think that is the standard across the board for the 12" wide weld stuff.
Honestly I think with some minor trimming on the lower valance and possibly the bottom rear of the front wheel well and they should fit. I was going to run 325/60R18 mud country's on them with a stock height truck.
Super-Stroker
I had 18x12 -51 offset with 325x60'son my 6.7 and it was fine as long as you didn't hit a dip hard at full lock
