Fuel bowl deleate
swinky
Eastern, Nc
Anybody know what fittings I need to get rid of the fuel bowl. I already have a 1/2" feed so I just need to know the size of fittings of the lines going from the head to the bowl. It's an an6 I believe?
Sent from my HTC One M9 using Tapatalk
swinky
Eastern, Nc
Any idea where I can buy some -6 lines already made. Then I'll do a -6 -6 -8 tee.
Merc82
A Wix 24770 and a Fleetgaurd 142784S will fit a Cat 1R-0749 fuel filter, that filter is what I have got for my setup.
swinky
Eastern, Nc
So can I get the hose already made with the fittings on it? Any idea how long they need to be.
Six_Sloww
Southeast MI
You'll want to mock it up how you want to route the lines, because they won't be able to fit where the stock lines go.
And it depends where you route your y block or T fitting. Mines close to my driver side frame rail so I think the line that went to my passenger side cylinder head is almost 3ft long
Six_Sloww
Southeast MI
Either way, if you're only making hoses from the y-block to the heads the cost difference will be negligible. If you're rebuilding the whole system, yes you save a considerable amount building your own lines.
powerstrokedkid87
New Jersey
when we do them, we go from the pump forward so we tend to just make the lines, its rare that two can ever be ran the same way, every truck is always packed with different crap
HOOV3R
Central PA
My fuel system is reverse feed to minimize lines in the engine bay. IMO you are better off building your own lines. They're very easy to build, and you can actually get the correct length and routing you want.
FaSSt9602
Gilbert, AZ
Strictly Diesel is introducing their fuel bowl ****** kit, just got an email on it this morning. Probably not the cheapest option, but you know it will be quality.
6.0L Powerstroke FUEL BOWL ****** Regulated Return
Same Flow and Pressure Improvements as our Standard Regulated Return
Eliminates Factory Secondary Fuel Filter Bowl
Designed to Work with Driven Diesel and other High Volume Fuel Delivery Systems
Shipping by Mid September
slc dzl
Riverton, Utah
It is a amazing kit and the fit and finish is top notch.
