Agjake11
So trying to get the last details setup before the truck goes to PSE. ive got Dozers Regulated return with fuel bowl delete and planning to stay with the stock pump for now.
couple questions, the kit has a t fitting for the feed lines to the heads and im assuming that the stock feed line to the fuel bowl isnt an an male fitting. so what adapter is needed to go from the stock line to the T fitting?
The next thing is im still going back and forth on where and how to add an extra filter with the fuel bowl being deleted. If im having to adapt the stock line from the OEM HFCM to the T fitting it seems that it might just be easiest to get a hardline to braided adapter and then just run braided line to the filter and then from the filter to the t Fitting.
the other option would be running the hardline adapter to the inlet side of the HFCM and having a filter pre pump. this would require cutting the stock hard line to add the filter or it would involve adding a sump with braided line to the filter and then the hardline adapter
or is this extra filter not necessarily needed? Looking for advice/suggestions as getting these last few things ordered are the main only things left before it heads over to dorians
Adapter in question
http://www.anplumbing.com/search/index?yt0.x=0&yt0.y=0&yt0=submit&search_text=165006
Adapter in question
