fuel bowl delete with stock fuel
madman1234509
mayfield, ny
There have been tests and deleting the fuel bowl does not net you any difference in power. Deleting the fuel bowl only cleans up the engine bay and sets you up to run dual fuelers. When Wayne was doing testing he came up with this, and Jared at RCD made 800hp with his fuel bowl still intact.
08BIGRIG
WI
im looking to do this also but with a airdog at the same time, do you have to remove the turbos the get to the fuel lines?
Yes the turbos will need to be removed to get to the lines on the hpfp that are behind the turbos and under the heat shield. It really isn't all that bad to pull the turbos and do the install yourself in your driveway or garage. The hardest part of the install will be getting the up pipe bolts out while the cab is on. Good luck.
