fuel bowl ****** wiring harness
rpm-inc
Is there a fuel bowl ****** wiring harness available? In the middle of ******** mine with e fuel. The existing harness is fubared. I need it only for the ipr, correct?
rpm-inc
I need something to replace what I got. Could just make my own to get rid of all the fuel bowl crap. Surprised no one makes one.
old man dave
Petaluma, CA
I think the injector plug on the UVCH is the same as the IPR plug if you need one.
You are right, IPR is the only thing left when installing e-fuel.
Last time I checked, the IPR harness was still available, but quite expensive.
rpm-inc
The plugs are still good, the wiring insulation is just brittle/cracked/missing. I will look to see if I can find the pins and make a new harness for only the ipr.
old man dave
Petaluma, CA
I was trying with the medal clip one.
YOu guys got me curious, maybe I was just repeating internet legend. Had to go down to the garage to check it out.
Well, I had a spare wire bail UVCH laying around so I tried plugging it into the IPR. Slipped right in.
