Fuel Cell
Debono98
Ontario, Canada
For you guys that run a fuel cell. I'm looking into getting a 10 or 15 gallon for my truck this year. Is there anything special needed or will any steel fuel cell work? Will I need a special float because it's diesel? Idk if diesel will eat away at anything in your typical gasser setup. Let me know what you guys think! Thanks in advance.
05wh250
hendersonville, nc
I'm in the process of putting one in my regular cab. 20 gallon with built in aeromotive pump and a pre filter. Called isspro and they built me a sender to use the stock gauge.
Debono98
Ontario, Canada
Right now I have an aeromotive pump on the truck. Was hoping I could still use it. Just need a sender for the cell then? What'd that run you if you don't mind me asking?
