Fuel for 250/200%
strokinak
Running an injector what is the best way to go for a fuel system? Would a regulated return get me by with possibly a sump or 5/8" draw straw, or should I go with something more like Irate's complete kit?
strokinak
So the factory fuel bowl and fuel lines to and from the tank are adequate to maintain fuel pressure with those injectors?
Strictly Diesel
Phoenix
Bigger pump and lines for 250s is a must. Stock pump and lines are too small.
You could do it with the filter bowl and a regulated return, we've had several customers make big power through the bowl...but most prefer not to at that power level.
ryanss22
upstate central ny
I made my own kit for my OBS with 3/8 braided SS lines,going from a single stock pump to a dual stock pump set up with water sep and fuel filter, an areomotive fuel pressure reg at the heads and a reg return.. Have about $500 in everything... But had to fab mounting plates and run my own wires and cut and fit all the right fittings I need'd. Def not a just bolt on kit...
