Fuel Maverick D262 22x14 -76
Tarheel_6.4L
Memphis, TN
I'm currently running 35" Toyo MT's on factory 20" wheels. I've had my truck for a while now but just got the desire to lift it. Can someone guide me in the right direction as far as a quality lift to clear 22x14 wheels. I've looked around online and it looks like I can clear these wheels with a 4" lift. Thanks in advance...
ncollins64
winchester springs, tn
I'm running 22x12 with 35 nittos and I'm running an icon 4.5 lift and still had to trim my bumper to clear properly. Either way I'd reccommend icon/ouo for lift and components.
truckman1974
As a comparison, look at my photos. I have an 8" lift with 37" tires (22x12's). You can see how close the tires are to the cab of the truck on the front tires. You might be pushing it trying to put a 22x14...that's wide.
(I realize comparing a 4" to an 8" lift is apples to oranges...I'm just saying, as a reference, look at the pics)
BeauxPete
Shreveport, La
I have 37s on 22x14 with 8" lift and still run full lock. Buddy has 4" with 35s on 22x14 and tires are ripped to shred from bumper and inner rubbing. They are big wide wheels.
SEABEE08FX4
Montgomery TX
Bumper? I got the same wheel size and slightly larger tire ( 3225/50R22 ) on mine with 2" less lift and only had to trim the finder liner. Check your track bar, your axle may be pulled to one side more than the other.
ncollins64
I did adjust my trac bar. When the tires would be in a slight bind it would big he bumper so I took 1 inch off the ends
Tarheel_6.4L
Memphis, TN
So it sounds like I'll need to run at least a 6" lift to clear. Icon seems like they specialize in lift kits for the Super Duty so I'll most likely run with their system. Pardon my ignorance but what does -76 stand for in 22 x 14 -76?
Tarheel_6.4L
Memphis, TN
@ Mink, do you have any closer pictures of your truck? I'm trying to get an idea of how 33 x 12.50 would look. I'm currently running 35's so I'm not sure if I want to go any lower.
Black AOD
Ohio
