Ive always wondered his, and will be doing this with my build. I understand the cost thing and guys using stock up pipes, or modified stock up pipes where they dont want to put another pipe on an up pipe. Gating around the VGT into the down pipe just seems like such a waste, and some where along the line they started doing this.
Im not going to have a "kit" for my build but do plan on gating, both up pipes, around the HP turbo and into the hot pipe between the HP and LP turbo. There will also be another gate installed on the hot pipe to gate around the atmo if its needed with the 100% nozzles and possibly some nitrous. So Ill have 2 40mm gates, one off each up pipe, and 1 50mm gate gating around the atmo if needed. Its probably overkill to have 3 gates, but wanted to try it.
