TD-5
If I do a gear change from 3.55 to 4.10 or 4.30, how does the ECM know the new gear ratio?
Is there a base parameter that is accessible thru IDS or similar programming to change this, & then do the fine tuning with tire size?
Or is it all done thru the tire size parameter?
