Gearhead stage 1 cam
SleeperDuty
One of the sled puller's on here have one of gearheads cams. powerstrokenstang is running one
Powerstroked162
On Da Juice
Wa. State
make sure you see the HP numbers since most CAMS make less that stock HP.
Mike Ontiveros proved that Matt's cam worked. Dyno numbers, track numbers as well as some flow sheets. He isn't the only one either.
There is one or two grinds on the market that have been proven to make less HP then stock. The stage 1 from Matt isn't one...
CSIPSD
Bend, OR
Hey now... I have more or less filled that hole with concrete. I hit the bottom and most seem to have seen the light down there. SO I filled it in with 5000psi concrete with air and 2% accelerator.
Should be hard to get thru now.
