Anyone from gearhead, what is the reason behind demanding 27k RP?
The injectors can handle it and if the pump maintains in the case of duals or modified singles, it is a Win-Win... so why not.
:whs: My gearhead tow tune (Race) runs exceptionally cool lol.
I had another superduty on a trailer with the cruise set at 85+ and didn't break 1000* even on hills. On flat ground I was running 7-800*. Trans, Oil and Coolant were all prefect.
You could contact rockentech.com and order new fuel lines for your elite kit, those lines fit the elite kit perfect. It would just require you to bend them into the needed shape.
Same thickness lines ? If so have fun bending.
You shouldn't be getting spikes... if you are let me know and i can make changes elsewhere. Or i can just put the pressure down to whatever you want.
What are you towing? I towed my boat 11-12k lbs 500 mile round trip through Kentucky & never seen EGT's over 1150 on Gearheads hot street. That's w/ cruise set @ 70-75mph the whole way. I have basically all the add ons you do!
I guess I'll try the race or maybe the street. I'm towing 15K through the mtns with 8% grades. Normally tow with Spartan 275 or KEMs 345 but like the thoughts of Gearheads not smoking out my white camper lol.
what is everyones RP at idle? Not sure if my pump got wounded when the line blew or if it's down because it's cold? it was like 5k-5200 at idle and went between 4900-5400 stopped at a stoplight. I don't remember what it was before.
