gears
GM Duraturd
New Riegel, Ohio
Really depends on your power level, rpm range, and desired final drive ratio. Out of the factory choices, 4.10 would be your best bet.
GM Duraturd
New Riegel, Ohio
My old truck had 4.10s. If your going for a dedicated pulling truck I would look into 4.88 or even higher. Theres a good calculator online to calculate your final drive ratio depending on trans, transfer case, gears and tire size and then charts for wheel speed per gear and rpm.... I just gotta find it.
PM Replyed btw.
