going threw batteries!
dommel01
Ok not even a year after.i bought my my truck i had to put new batteries in, that was a year ago and i went to start the truck this morning and it was dead again, after i drive the truck the batteries recharge so i think the alternators are good, anyone have the same problem or know what mine could be?
POWER-STRUCK
Indiana
brand of batteries and deep cycles can affect the life expectancy. if you have something draining the batteries and then have large alternators charging quickly it can harm the batteries. also if heat blankets are missing and the hold down bolts are gone you will kill batteries. get a good name brand battery and do not get the high cranking amp models
(motorcraft, interstate, exide 650-750cca)
dommel01
They are motorcraft batteries, and what are the heat blankets? I have the holds Downs but idk about the blankets
Hammer Down
when i bought my 09 the oasis showed the batteries had been replaced earlier that year and i had it maybe nine months or so and it started having issues starting. tested and one battery was bad and must have drawn from the other battery so i had them both replaced. i couldn't believe the new batteries would have failed that quickly.
dommel01
Yea when i bought the truck they out new batteries in it, about a year later they were.dead, and.they were motorcraft so i got free replacement, now about a year later they a dead again, anyone know what the hecks goin on? And no i live in pa
Dzchey21
wyoming
Thanks for you help on the ACTUAL problem
I think you should be cut off from the internet after 9 pm
You need to monitor the charging system, it sounds like the batteries are getting overcharged and boiling the batteries, maybe during the summer its not a huge deal as you dont need the most cranking power from the but you notice they are compromised in the winter.
You should never see the charging system above 15 volts, normal would be around 14.3 volts with good batteries.
Good way to monitor is a tuner if you have one
B.Warning
NE Missouri
I went through the same thing. They were replaced under warranty and failed again. I replaced them with interstate batteries and haven't had a single issue. Not sure what the size is but there the same ones I run in my semis. Actual size is a lot bigger, they were a tight fit in the tray and the hold downs didn't work.
Dzchey21
wyoming
you went to a group 31 battery it sounds like, shouldnt really have to do that to make it work.
And fwiw just so you guys know the higher the CCA the less longevity the battery has. I realize that in some situations its nice to have a set of 850cca batteries but usually 750 is plenty
dommel01
dustin, yes i am monitoring with a dash daq, what do i have to do to monitor? and im not sure what the cca is ill look, i bought the truck from a dealership and had them replaced with the same batteries im assuming they are the correct cca, ill look then
Dzchey21
wyoming
There should be under ford specific a pid for battery voltage
If not scroll outside of the ford specfic to b analog and there should be a pid there for battery voltage
Daddyusmaximus
Powerstrokers like to upgrade their trucks... why not the Batteries? Put in a pair of Optima Yellow Tops.
bad12jr
Optima's have been going down hill lately. Check and clean ALL your grounds and connections. Especially being up north the lower grounds on the block probably don't look the best.
Sent from my x2 chillin in the middle of no where
Smokyred
Wellington, OH
Optimas are trash around here, you're lucky if they last 2 years in a diesel. Getting the better Motorcraft batteries works around here, I've put them in quite a few trucks now and I've got some 7.3's with 5-6 years on them.
If you're killing batteries you've got a charging issue. You need to test your alternator and check your cables and mounting points.
Dave
