GTX 4202R 1.15 housing ?
mattman347
Readyville TN
What are you guys commonly running on these for turbine housings? The 1.15 housings are on back order from Garrett for these!! Are you guys using a precision housing by chance? I am being told I can use a 1.01 or 1.28 because they are in stock. Thanks guys!
Dieselboy.
Surrey B.C.
Depends on the truck. CC ? Reg cab etc ? And what injectors ? HPOP ?
I believe precision does make a turbine housing for that turbo yes.
FWIW I run a 1.10 on my setup
bigjake0524
1.01 and let the gate do the work on the top side... But I can get the 1.15 housings if you need one, if you cant come up with one.
vanderchevy18
Benton, Ks.
Whenever jake gets my gtx4294 I'll be running a precision 1.12 housing. I have heard that precision's housings are a tad looser than others. The 1.12 is more like a 1.15. I had a .98 which is supposed to be like a 1.01 on my gt4294 and it spooled up incredibly fast, but egts were insane. Don't know if that helps or not but I'm sure jake can get one of those for you too.
