Guess the Lift?
HulkHartman
Hey everyone, Anyone have an Idea on what type of lift is on this truck? I'm guessing Zone Radius 6inch. Im looking at buying this truck and was wondering. Also, is there anything that looks to be an issue? I know the transmission was repaired about 20k miles ago on the truck under warranty by the dealer. Im looking to get the Oasis report now.
Thanks!
driveshaft is too short. the oil sprayed on the cab floor is from the slip joint coming too far out of the transfer case on big bumps or under severe axle wrap.
Ah ok, so what does it take to lengthen it?
I believe pro comp sells a spacer to put between the rear axle flange and the u joint. But it would be better to have a proper shop modify the shaft as was suggested already
Sent from my SM-G935W8 using Tapatalk
