truckman1974
- Joined
- Oct 18, 2014
- Messages
- 872
- Reaction score
- 0
I will have to be very careful then. Thanks for the warning!
That's a great reference picture, thank you. What I'm thinking I'm going to have to do is..... You see the little side wall pieces that are touching the magazine well and along the top part of the slide? I'm thinking if I use a dremel and totally remove those side wall pieces then that whole compartment will just be one big open square (that's the part I need measured)....then I can either fiberglass the safe to this open square piece, or attach it some sort of way that doesn't look ghetto and then the little lid to that compartment will be able to lay over the top of the safe. The safe (underneath) will be anchored to some anchor points inside the console.
I think you need to leave some of it to hold up the cup holder portion up, assuming I understand you correctly and it will be put back on top.
Why not simplify this...........get a ruger lcr (or similar in size). Use a hole saw and drill a hole thru the bottom, weld some sort of anchor point in and lock it up that way?
The lid of the small square gun safe/lock box will be the portion that will serve as the portion that holds the cup holders up. Actually the false bottom that is already in the truck will just lay on top of the safe and then the cup holders will go into the compartment as they do stock. Just instead of the way it looks from the factory when you lift out the false bottom, there will be a lid to the lock box there.....(assuming everything fits as I'm seeing it in my mind....it's hard to know for sure what will work with me being stuck over in West Africa).
G27 in a Galco Holster. Had no idea about this hidey spot until I read the post. Thanks
