Half Empty Shotgun build thread
BWCbuilt
central US
Well, it has been decided..... Building a new frame from scratch with an a-arm front and cantilever rear.
BWCbuilt
central US
I figured I'm not going to get it done for lst anyways, so I might as well do it big and take my time.
BWCbuilt
central US
Well I have some chevy parts on their way that were donated to the cause, If those dont work i will probably just be spending some quality time with the welder and tube bender.
rat49f6
Vernon,NJ
I got my clip for $500 any 8 lug chevy front clip should work 4wd or 2wd are the same
use the clip as a start point for the frame
2x4 box back off that straight back
I have pics of my 6 link cant set up if you need
Sent from my T-Mobile G2 using Xparent Green Tapatalk 2
BWCbuilt
central US
I have your six link pics saved....unless you have better ones that are not already on the interwebz
rat49f6
Vernon,NJ
No but I can take more if need be...
Most important thing is getting the intersecting point pointed at the grill... While thats confusing its much easier than the actual calculations
rat49f6
Vernon,NJ
To bad chevy ld is 6 lug...what spindle are u planning to use
rat49f6
Vernon,NJ
5 or 6 will defiantly have more off the shelf options in positive offset but those wheels will not be built to hold a 1000 pound engine like 8 lug will
most likely you will need custom wheels no matter what
BWCbuilt
central US
This truck seemed to be able to hold it all in on 5 lugs pretty well, I have more pics of the a-arms but did not get to talk to the owner much
