having some issues after dpf delete
907stroker
Alaska
ok so yesterday i did the dpf delete. had to run canned tunes until i got home ran good loved how it woke it up. and that just with the sct livewire. i got home and downloaded my gear head tunes and put them on the tuner.
went out to the truck to load them.
i first tried to tow tune to start small but im having problems.
when i tried to upload them it was in the ecm storage part for to 99% and just started making clicking noises and doesnt stop. had to unplug and start again.
try the street tune but when i get to the user options the screen starts going crazy and fills up with all sorts of letters,numbers,and other icons. had to unplug again and start over. tow keeps doing the same thing but with the street tune i tried it with saying the egr was deleted and it finally worked. but not the tow tune, and i am scared to try the hot street file.
i even just tried to go back to a canned tune and it told me i had to go back to stock to switch tunes. whats going on?!?! i cant just keeping going back to stock i only have 3 unlocks left. and i am terrified of loosing my stock files.
jdgleason
Fort Collins, CO
The unlocks are only used with different vehicles. You can tune yours as many times as you like. I would load the stock file back into the truck and try updating your livewire.
907stroker
Alaska
i updated it a few night ago before loading the new tunes on it. and if i return to stock it used up a unlock
907stroker
Alaska
so, just went out to try to go back to a canned tune and i cant. it says strategy code is wrong or different. but it still has the street tune on.
also i pulled a couple of codes
u0115
and i had TWO u0100
what is going on with my truck. did i loose my stock tune? i tried to save it to my computer and it gave me a 3 page list of weird stuff that i cant save the stock setting
WoodBoy
Alabama
U0115 and U0100 are normal miscommunication codes due to the reprogramming of the PCM. Ignore them. You tried returning to stock and then loading a canned tune or just loading a canned tune straight from a custom?
907stroker
Alaska
Loading a canned tune straight from custom tune. If I go back to stock ill end up loosing a unlock and would only have 2 unlocks left
907stroker
Alaska
But I cannot even run other custom tunes either. Once I get to where it does the ECM storage thing it gets to 99% and then just beeps alot and freezes
drunk on diesel
What benefit does that have with the OP's question?
Like I said, they had a problem burning unlocks on the same truck. Contact SCT.
In the mean time, if he wants something hassle-free, there's still time to buy an h&s.
Just trying to help
907stroker
Alaska
well called sct today and they did their thing with the tuner remote in and flash the tuner again and now it seems to work.. havnt tried swapping around tunes yet, will do it later
