Head studs or not
99powerstroke
I am debating on doing head studs on my 7.3 before I get new tunes to turn up the fuel. I am running a regulated return, 38r with just the 1.0 housing, 250/100%, etc.. I am also thinking of doing comp 910's too. What do you guys think?
Thanks
Southmike
Do the studs with the injectors, make sure you have the right tunes for the right injectors, even if it means installing atwo by four under the go pedal.....
TARM
Its up to you. You are right on the line as far as CP and what those injectors with that amount of air flow can do. how its tuned would make all the dif. The safe bet is to do them. That being the choice do them with the valve springs push rods and injectors as it will all be out anyways. Take the little bit of extra time and measure your spring height and use the proper shim. JEgs sells a nice Shim multi pack Kit of various thickness shims as well as low cost micrometer that is plenty good for this job as far as accuracy goes.
