Head unit powers off - Help
Rob D
Massachusetts
Have an aftermarket head unit in my truck. Never had a single problem with it. Recently truck had to have cab off work done. When truck came back the radio now will power off when accessories are used (mostly if engine is off) It is as though power to the radio is interrupted. This happens when turning AC on, pressing power window buttons, or even pressing the brake pedal. Radio also shuts off when going over bad bumps while driving. I tried plugging the stock head unit back in and the same symptoms happened. I also checked the ground locations behind the removable panel under steering column, and by parking brake. Have wiggled every wire possible and could not get radio to cut out. Any ideas?
snoracerx
Possibly the accessory relay when the taxi quits try the power window if they don't work replace the relays
Sent from my iPhone
Rob D
Massachusetts
Power windows work fine. All accessories work fine. Batteries and alternator were also tested and checked out okay.
