Heater not warming up!
95-F-2FITTY
arkansas
My truck is not heating up like it should it only blows warm air.The temperature gauge only goes up around the n or o on normal. And i also noticed my coolant resovoir never pressurizes. i can take the cap off without any pressure when its been running.
zilla68
Moore Oklahoma
mine does the same thing, when I put it on high idle it warmed right up, the engine is just not building enough heat, block off the grill and that will help.
95-F-2FITTY
arkansas
Ok i will try blocking off the grill i am not low on coolant though. Im located in northern arkansas just got like 10" inches of snow!
95-F-2FITTY
arkansas
Alright so i blocked off my radiator last night then plugged the truck in its around 15 degrees outside this mornin. So i start it and let it run on high idle for 10 min and then i take off for work. It takes me about 15 min to get to work add or subtract a few minutes for red lights and traffic. When i got to work my temp gauge was on the n and just blowing kind of warm air.
4x4given
Sticking blend door or actuator? Mine was doing the same thing a couple weeks ago. Opened the glove box and dropped it down, looked under the actuator with a flashlight at the actuator shaft and operated the temp control knob and observed limited movement.
Popped the actuator out and tapped it a few times and it started swinging full range. (at least further than it was). Bought a new one at O'Reilly's (lifetime warranty) for about $30. Problem solved.
95-F-2FITTY
arkansas
Ok i checked the temp door and it is working full motion. Is the blend door the one that is located under the hood on the firewall?
Rideracelivemx7
Montana
how cold is it? I know this time of year my theromostat doesn't even open, all rad hoses are ice cold and no pressure in the bottle. pretty sure anything below 50 or 40° these motors start to struggle to keep warm.
Bugman
Gypsum, Co
If your morning drive is only 15 minutes you are not going to get the truck up to temperature. That is the problem with diesels, they run cool and need to be worked to get heat flowing. For that short of a drive you could pull the fan and not even worry about it along with blocking most of the radiator with some cardboard.
JCart
Kamloops, British Columbia Canada
What I have done is purchase some plastic board (like cardboard only plastic) same width as rad and a few inches taller. Side it down between the rad (in front of) and behind the AC condenser in this way if fits right up against the rad. Seems to help, I really need a hotter Tstat I guess. Also have the Lund grill inserts but they really only keep the salt and gravel from hitting/coating behind the grill.
jrc
