Help getting it up
riotrob
Louisville KY
I have a 2016 f250 lariat leveled with RC spacers. I just put on a set of 20x10 with what I believe is a -24 offset. They are wrapped in 35x12.5 exo grapplers. Stupid great deal I could not say no too. I trimmed the liner a little and cleaned up the front bumper mount to keep from rubbing but still getting a little. Will a 4.5" lift be enough? If so should I stick with RC or go something else. Don't want to go so high that I spend 2k on a lift. Any help is appreciated.
bigrpowr
<How I Fly
Administrator
4.5" will do it. thats where i'm at with similar combo.
Swampfox
TN
I have a 4.5" Carli back country kit with 35 ridge grapplers and 22x10 wheels with the same offset. I started with a level also and had to go up to a 4.5" to keep from rubbing without trimming.
riotrob
Louisville KY
I have the 1.5" level right now. Good to hear that 4.5" will do it. Any good deals on Carli? I hear nothing bit good things of them. I could not resist the title.
riotrob
Louisville KY
Also at 4.5" of lift do I need to worry about the drive shaft or is the 4.5" lift kit all I need? Just want to make sure I do it right.
bigrpowr
<How I Fly
Administrator
we sell carli with a forum discount, and no, drive shaft angle will be fine.
Swampfox
TN
Here is a picture to show the difference. Have some more I can upload too.
Nj67
South NJ
3.5 inches cleared 20x10s with -24 offset for me. Currently running 22x12s -44 offset on same 3.5 with 35 ridge grapplers now. Had to do same minor trimming as you mentioned.
NCSU dirt man
Ft. Bragg, NC
i'm running 3.5" with 20x10 gear wheels with 35x12.5 ridge grapplers. the only time i rub is pulling into a parking lot too quickly and it varies with curb type. no trimming here
Powderhound
Helped install a Zone lift a couple months ago. Not to terribly impressed.
Couldn't believe it didn't come with a pitman drop arm. That's an accessory for there 4" lift.
I went with the Cognito lift and am very pleased, my only complaint was the directions were low quality and the sway bar drop were interchangeable for each side causing one side to show the open box design. Just a cosmetic complaint.
Jomax
Arizona
You don't need a pitman arm drop till after 4.5in.
NCSU dirt man
Ft. Bragg, NC
^ yea that's what I thought too. I don't think I've seen a single kit 4" or under with a pitman drop arm
now i'm not saying Zone is exactly awesome as there's definitely better options out there. but for the price it's kinda hard to beat (basically it's an intro level BDS lift) and Zone offers their cheaper "Fox" shocks as well (not sure on their ride quality though) but you can always upgrade shocks to whatever you like later. I was seriously considering their 4" with radius arms until i found a local guy that got me my 3.5" Icon Stage 1 kit for cheaper than the 4" Zone Radius Arm kit
