Help H&S sd card????
zack birge
Oklahoma
Ok so I took my card out and out another file in the custom folder for mcc and when I loaded it back it says "error finding custom directory" after I select download custom tune...what happened? My SD card is properly inserted in the mini maxx. I tried loading the factory canned files and it says insert SD card? Do I have a bad card? If so what do I do to fix it?
CT9AIX
MA
It's just a standard run of the mill SD card so you can try going and buying another card and reloading the entire MiniMaxx software file from H&S's website so atleast the truck will run. Once you get to that point you can try reloading the custom tunes afterwards knowing the truck will move if you need it to.
zack birge
Oklahoma
So your saying it possible took a **** and I can just get another micro SD and load the files from h&s website to it?
CT9AIX
MA
Crap... I forgot with all this EPA stuff going on I dont know if you can redownload all the DPF removed files from their site anymore. You used to be able to download the entire software file to start from scratch, then you could upgrade to the HD300, easy tunes ect...which were all DPF delete ready tuning. Youll have to search their site... it might be gone now after the EPA junk. Other than that Im not sure what your options would be... I've never had it happen to me before.
drunk on diesel
yes, you can still download everything
You can copy/paste your entire card to a new folder, do a complete reformat of the card (not quick format) FAT/FAT16 format NOT FAT32!!!!!!!!! Title the card MINI MAXX (all caps)
Then copy/paste your files back onto the card. I've had that work more than once. But you may need a new card. Must be 2GIG
08BIGRIG
WI
Make sure that you delete all the files on your card now before loading the entire new card from the H&S website though.
BFT
southern cali
Not saying it was right but FAT32 was the only way I could do to format my card
BFT
southern cali
I would do the FAT or FAT16 like is recommended through the H&S. you could try using a new 2GB card and format it and do all the info like mentioned in the site
BFT
southern cali
Yeah, it was weird. The first 2 just didn't want to do it so we tried the 32. It works so I'm happy.
08twinturbo
Strange. I've always done FAT/FAT16 per H&S recommendation. If FAT32 works, so be it! :D
This is the correct setting. This happened to mine as well. Card needs to be reformatted as mentioned. After new files are downloaded you should be good.
