Help help help codes no power please
B585Ford
WV
I have never seen the inside of K16 so this is why I ask and for a Canadian, you seem pretty sharp, but if VCV wouldn't open enough (due to a short in the wiring), wouldn't that cause fuel not to get in and possibly cause this? In the OPs case, I am guessing not cause he eventually makes RP, but if he couldn't make RP, wouldn't that be a possibility?
forcefed6.4ford
Medicine Hat... Again
Usually a chafed harness comes with a voltage DTC with a no start. His rail pressure is steady when he is WOT, even when the boost builds. So the way I see it, its not a volume issue.
TXlineman83
Austin, TX
What makes it worse is all the tow company business cards my friends keep sticking all over it. Kinda runs salt in an open wound.
