Help ID this part....
JohnT24
OXFORD CT.
While pulling my fuel pump and bowl I noticed the nut had fallen off a shaft coming out of the HPOP .... a solenoid slides over it with a spacer and a nut...
I found the nut and spacer in the valley .. but not sure if I have the configuration right...
Does this look right?
The truck ran fine up until I found it.... who knows when it fell off... nut was a little corroded but threads look OK
If I have the configuration right, I'll put loctite on it.
pics in next post...
JohnT24
OXFORD CT.
found a pic online.... looks like I got it right.
thanks for the ID.
Injector Pressure Regulator valve.
JohnT24
OXFORD CT.
If you are going to put Loctite on it, make sure it is blue Loctite, not red Loctite.
Too late..
no biggy... usually a little light heat will help removal...
I've owned many harleys... I'm well versed in loctite... :evil
green loctite is a Biotch...
Arisley
Arlington, Texas
I got rid of the cheap little tin nut on mine. Took the IPR to Home Depot and found a nut that fit it. Can't remember what size it was.
JohnT24
OXFORD CT.
Is it a common thing for the nut to fall off of these?
I've never really been down in there.... bought the truck new... in 95
I reckon the wiring harness and plug held the solenoid in place..... :shrug:
JohnT24
OXFORD CT.
I know,
I keep calling it a solenoid....
looks more like a coil of an old Meyer snow plow pump...
Arisley
Arlington, Texas
It is a little electromagnet that moves the actual valve back and forth. I allows more or less high pressure oil to go to the injectors.
countrylover
Can you please give me a better shot at the picture like a bigger area
JohnT24
OXFORD CT.
countrylover,
a total post count of 3 incoherent thoughts.... all in this thread.
Classic.
welcome.... I think... :popcorn:
Arisley
Arlington, Texas
What is a ipr valve
It is the valve attached to the HPOP (High Pressure Oil Pump) that controls the oil pressure going to the Injectors. The injectors use this oil as hydraulic fluid to increase the fuel pressure from 60 psi to 20K or higher psi to atomize it before injection onto the cylinder.
