HELP! Loud injector buzz / Fuel prime (video)
rman
SoCal
Just got my truck back after bulletproofing and I noticed the injector buzz is way louder, and there is a high pitched hum at the end of fuel prime. Like a dying goat.
My tech says it's normal, but it's really, really odd....
Fresh heads, gaskets, studs
Standpipes, injector seals and orings
Blue Spring upgrade
new ICP/harness
new IPR screen
a ton of other updates
https://youtu.be/dw1Hcu9XDwg
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Sent from my Nokia 5160 using Snake
Derkperk
Twin cities
I was thinking vac pump until I actually watched the video. My truck doesn't make any of those noises. Not normal.
rman
SoCal
guy on the org has run into it a few times, likely the oring behind the plastic seat for the brass plunger. on the blue spring.
or perhaps a dying goat. still a possibility
rman
SoCal
turned out the oring on the plastic piece, behind the brass plunger in the blue spring kit was missing. runs like a beast now.
i guess only 03/early04 have them
