bluedge8
watch your hpop pressure when cranking, mine will go all the way to 3300# when she cranks a long time and the gp's aren't working.
first things first, the idm delivers 110 VOLTS, NOT 10V!, don't go playing around with that wiring when cranking, it will knock you on your ass! Second, I don't care if the hpop res isn't going down, you need 500 psi for the computer to start firing inj's, period. You need to look over that system before you do anything else. If your hpop lines have the "quick disconnects" then start there and make sure they are clicked in right, I didn't have one clicked in on one of my trucks and it would not fire.
Should I try to syphon out the old oil in the HPOP res and clean the IPR?
How many miles on this engine?Pull the injectors and send em off to get checked/ rebuilt by one of the sponsors here. Change all the injector cups.
