Hi I'm new to this site and diesels. I have an 2003 f250 6.0. My truck started jerking when i put it in drive or reverse. I was told it was a transmission solenoid. So I replace all 7 of them. Put it back together and now when I put it in drive and not touch the gas it pulls itself for like 2ft then it's like someone hit the brakes or chalked the wheels. I put it in neutral then back to drive and it starts to pull again than stops like someone hit the brakes. When its in neutral it rolls freely. It does not happen in reverse. When it happens and I hit the gas it feels the same like something is holding it back. Also does it in 4x4 and 4x4 low. No check engine light no codes. First I thought it was a brake problem but then it doesn't do it in neutral or reverse so I'm confused. Thanks for any help you guys could provide.
Sent from my SM-N920V using Tapatalk
