Help won't run
White64
The other night my truck ran great!! The next morning I get into my truck and crank it. I let it idle then I pull out of my driveway and it starts spitting and sputtering like its starving for fuel. Since then the truck will not crank. And has had no prior issues with the truck. Did pull a few codes from it and can't make heads or tails of what's actually going on with it. Codes are p008c , p179a , p0000, u0253. And this morning I got a p0291
The truck is also a job 2 truck and has been ******d now would I be wrong to check the fpr sensor or gas pedal in this situation
Bigboytoys
Ya you have an issue...
P008C Fuel Cooler Pump Control Circuit/Open
P0000 ? are you sure it wasn't P1000....?
P1000 On-Board Diagnostic (OBD) Systems Readiness Test Not Complete, Don't worry bout that one if it was that.
P179A Controller Area Network (CAN) Engine Control Module (ECM)/Turbocharger Boost Control A Actuator Circuit Malfunction
U0253 Lost Communication With Accessory Protocol Interface Module, Air bag...
P0291 ? this one doesn't make sense to me
A FPS I don't think would do so that and neither should peddle, it will cause a no start but not those codes.
I might think your clock spring has gone bad, by the air bag code... my best guess....
