Lysons
2003 F250 7.3 no crank or start
Sitting in a parking lot with no tools
Any ideas?!
Any ideas?!
when you turn the key does the cel come on? is there a click or does the motor turn over freely?No luck.
What wire are you talking about?
I got it to start.
I wiggles the wires on the start and put it from n to p a couple times.
They have a ground wire by the way, as they bolt to aluminum.
Well good that you got it started...Now driving a Ford without tools you have the faith that I don't. Also if it is a grounding issue you can always run jumper cables from the negative terminals on the batteries to the block to see if it's a grounding issue should you not have a meter handy.
