HerLifted350
Was drivin' home from a rally a couple weeks ago (delayed cause I was trying to figure it out on my own/local help)... anyways... Truck was fine drivin' down the local side roads, and when I got on the highway... went to get off the highway to get fuel (still had about 1/4 tank, I try not to let it get below a 1/4)... Get to the bottom of the ramp and go to stop at the stoplight and the truck dies. :shrug: I blow it off as a fluke, put it in neutral and she fires right back up. Pull away from the stoplight, make my way to the fuel station, coast to slow down, blinker, turn into station, go to stop at pump and the truck dies...:lookaround:
Put fuel in it, fires right back up, and pull through and out of the station... Get back on the highway, car cuts me off so I go to slow down and the truck cuts out and dies... shift into neutral real quick, restart it and get goin' again... did this the whole way home...
Only does it when the truck is up to temperature... always fires right back up... Help! Luckily (well, not lucky... you get my point), a local member had surgery and can't drive, so I have a truck to drive for a couple weeks... but help!!!
