High beam fog light mod on 2002 f350
7.3 MACHINE
I'm trying to do the high beam fog light mod that i saw done on a 2003 but mine has different color wires (02) than the forum showed on the 2003. Anyone done this mod ?
"Ok, since no one was posting pics I went out and made took my own pics of the high beam/fog lights on mod.
Pull the lever horizontally with the plug, the wire plug will lift up while you pull the lever.
The wire to be cut is a green with black stripe on my 03 7.3 eddie X.
I crimped on and then soldered on a 9mm lug.
I located a factory ground location on the right side of the removed lower dash panel.
Bolted down the new lug with the factory single wire lug.
Stripped the end of the new wire after measuring and the end of the green wire coming from the harness plug. Don't forget to put the heat shrink on!
Wires pushed together.
Twisted.
Soldered.
Heat shrunk.
Heat shrink the end of the green wire coming out of the wire harness and put everything back together. Works perfect on my 03."
7.3 MACHINE
Not what I was looking for, I want to be able to have my foglights on with my hi beams.
