Homemade steel intake
Chrisf97305
Salem Or
I built this intake and I am ready for paint. I want to smooth out my welds with body filler or something and I don't know what to use. Will he heat of the engine shrink the bondo? If so what should I use. Or should I just put a good coat of paint on it and call it good.
Rideracelivemx7
Montana
Man I love your work, looks great. I'd just slap some paint and call it good. I like seeing welds but that's my opinion.
Chrisf97305
Salem Or
Thank You. I like doing things outside the box.
I like to see welds also, but not my mig welds. Had to weld some leaks up. did grind off the high spots and it will look ok in just paint.
Big Calo
What about using something more like an epoxy? Like maybe JB weld to fill them in. Might react better to heat.
Crownsville, Maryland
That looks wicked, nice job. I've seen worse that just gets painted and sold so I would just paint it. On a side not what did you use for all your hard lines any link?
---Clayton Watts
2002 eclb 7.3- back in business /for sale
2000 Chevy cavalier- sitting
1990 Chevy K1500- sitting for sale
race truck- in the works
2003 Subaru wrx wagon- new dd toy
sent from the sh!tter withTapatalk2
Chrisf97305
Salem Or
---Clayton Watts
I just bought stainless steel lines from a local hyd shop. bought a good line bender and a flaring tool.
I have almost 10,000 miles on these lines so far and no cracks or leaks. If you look close I also replaced my HPOP hoses with steel lines.
It looks great what are the lines rated for (psi?)
---Clayton Watts
Chrisf97305
Salem Or
---Clayton Watts
the stainless lines i used for the HPOP are rated at 20,000 psi
Petro
Lincoln Nebraska
I'd love to see this engine in person so I could trace all those steel lines and check out that twin setup, very very cool setup. Great Job Man.
2000wa250
Chris, didn't know you did the hpop lines in stainless as well. No issues with that? What size? What about fittings?
Lol how about a parts list for all the stainless lines
---Clayton Watts
Chrisf97305
Salem Or
no problems what so ever. i just used heavy wall 3/8 stainless steel. used 3/8 JIC fittings and flared the ends to 37 degre, used a flare sleeve and nut. got about 8,000 miles on the set up as of now.
Chrisf97305
Salem Or
---Clayton Watts
60 feet of stainless line and $300.00 in fittings
