How bad are these going to run?
Myerswelder
Greentown, IN
I am currently running a 2.5 leveling kit on my 06 F350. I'm running 20x9 xd hoss with -12 offset and nitto terra grapplers that are 295/60 and I trimmed the inner wheel well some to cure the rubbing. These tires are not gonna make it thru winter and I'm going to switch to 22's once spring hits. I found a set of 35x12.50 amp mud terrains with only low miles for $500. How bad are these going to rub if they do at all. Thanks for all the help
Koda22
Ruidoso, NM
Well it's gonna depend on wat size 22s you get....22x??? If it's with in reason, not 12 wide, I would think it wouldn't b any worse then wat ya got now,,,
Myerswelder
Greentown, IN
I should've explained it better. I apologize, the 35s I found are for my current 20. I'm trying to get away from buying new tires now then again in spring. The amp tires are basically just to get me thru winter.
Stroke2broke
20x12 with a -44 offset on 8 inches of lift will rub a little so just star at 22x10 or less and you will be fine
