how many of you repair your own FICMs?
Atsah
Maine
I have done it and it worked okay but some of the components on the circuit board are marginal at best.. Swamps replaces quit a few of the components when you send it to them for repair..
Mdub707
Mohawk NY
Your AE isn't getting a good reading either, do it with a multi-meter. The scanners can only read AS LOW as 40V, but not under. I bet it's worse than that. I repair them all the time. Doing 3 more tonight.
If you've never soldered before, it can be a PITA. I would recommend having someone who has worked on components like this before do it for you. I would also recommend re-staking the components after as well. I've found some suitable alternatives in Jegs and Summits (for staking compound).
jdc753
Norton, MA
When mine went out my dad resoldered it for me. I don't quite have the patience or experience for such electronics work but he has been doing it for longer than I've been alive. We repaired it November 2010 I believe and its been fine ever since.
One thing is even if the components and solder joints look fine, its best to just resolder them anyways. When my dad first pulled mine apart he didn't see anything wrong and no need to mess with it, but we ended up trying it anyways and it worked great.
Mdub707
Mohawk NY
I've pulled the staking compound off before (the orange goop on the board) and it has pulled some of the components right off with it, meaning they weren't even attached. There isn't even enough solder on these to run them through a re-flow oven. They are made in Mexico... haha
jdc753
Norton, MA
Yup!! Same thing happened with mine, one of the resistors (I believe) pulled right up with the compound. This is when we realized it would be good to go through it completely, removed all the compound and resoldered all the places pointed out in the write up I had. This is what I followed for fixing mine, http://www.competitiondiesel.com/ficm/FICM.pdf
MorganY
college station, tx
that is a great write up, thanks!
