How to determine gear ratio?
Glamping
So I need to determine what ratio my truck has. Other than pulling the cover shouldn't one of he letters in the vin tell me? Thanks for any help
webb06
Seneca, MO
Should be a metal tag on the rear differential cover. It'll be under one of the bolts. It'll tell you if it's there
Mark Kovalsky
SE Florida, USA
There is a data tag in the driver's door opening. There is a code for AXLE that will tell the ratio that it was built with.
You can also jack up the rear wheels, put the trans in N and rotate the tires one revolution. Have a helper rotate the other side while you do one side. Count the driveshaft rotations and you'll know the ratio.
