HPO numbers
Smokin 6.0
Indiana
Been awhile since I've delt with a semi-stock truck what High Pressure Oil numbers should I look for on a stock 02 with a T-500 HPOP.. Idle, through powerband, WOT ?? Thanks
littleredstroker
where the antelope play
WOT should be whatever the tuner is requesting from what i understand. Ive heard 2800- 3200 just depending. nothing over 45% at WOT
Idle ive seen DC at 7-12% 500-700
but dont take my word
Justin@DP-Tuner
On a stock truck?
480-500 psi at idle with IPR DC between 9-11% (assuming oil is up to temp).
2800-3100 psi WOT with IPR DC below 50%.
Cruising through power band ICP and IPR DC will fluctuate so much that it is too hard to give a good "normal" figure.
On a tuned truck, those numbers can all change.
