neverkickn
Does it matter if the shaft seal leaks? I have read that some leakage on a 6.0 pump is acceptable but what about a 7.3 oil pump?
But its the part that sits "in" the front cover right? If so, how the hell could you tell its leaking, and not just lube oil being thrown on it? Just curious
never seen a HPOP leak around the shaft seal (meaning that if it does, it's likely a problem).
FWIW, that seal is 'only' holding back low pressure oil...not HPOil.
