HPOP Suggestions
Rubyred
North Dakota
So for quite a while now ive been fighting the 1211 code and I figure its time to replace my factory hpop before it goes down on me. I currently have factory injectors, but plan on getting 238/100's would it be worth it to get something like a T500 or just go with a healthy factory replacement?
Sent from my HP 2000 Notebook PC using Tapatalk
PABowhunter
Another vote for the honey badger jr. Running my 250/100's well.
Your other options would be t500 or adrenaline.
Rubyred
North Dakota
ya I thought about the Honey Badger Jr also, who all has them besides Beans.
Gainesville Ga.
T500 has been holding up great in my 96 and cousins 97, for that small of an injector you can't beat the t500 for the price. Either way ya go, both mentioned are made by quality builders, just depends on your goals and how much you wanna spend.
Rubyred
North Dakota
That's just it, if a stock hpop can keep up with 238hybrids then its hard to justify spending more money on overkill. I figured i would throw it out there and see if there are any other hpop's besides what ive researched on to try out.
lincolnlocker
Central Michigan
if you are not going any bigger then the size you mentioned then a t500 will work just fine.. The adrenaline has been out for a long time and is very very reliable and the badger jr is proving to be a good pump too.
uw mitch
NW Oregon
I've been really happy with my t500. Works great with my PIS 160/30s
Sent from my SGH-T769 using Tapatalk 2
Powerstroke Man 6.4
Honey Badger Jr, T500 , Adrenaline they are all great pumps. I personally had a T500 in my late 99 with 160/100's but it always threw P1211 on hard boost launches or WOT runs . Don't know why but fuel pressure was good at WOT and idle. I think ICP was dropping off on the top end.
mandkole
Northwest
x2 with mj
are you certain that you need a new pump? unless you've confirmed that the rails are leakfree, this looks like a stock AD on tunes normally using oil. I wouldn't change the pump until the new singles are in.
thuglike
Linden, NJ
x2 with mj
Agreed.....
But if you decide on a pump we hope to be considered!!!
I have not updated in a while....
As of today we are closing in on 400 sold pumps with 9 failures.
All failed pumps were replaced at no cost to the customer.
(failed is defined by ANY problem, no matter how slight)
Rubyred
North Dakota
Ya maybe i will hold off on the pump it hasnt been giving me any trouble yet, no leaks or anything starts and runs good besides throwing that P1211 under a heavy foot. Save some money for them Hybrids also
