HPOP
SamW
Stuart, Fl
Well I have not really been reading the forums lately an my hpop is about done for. Are there any worthwhile upgrades out noe for an 06? I am running 205/75s and my pump cant keep up. I am only seeing 1750 or so at WOT. checked for leaks and all that...
Pizza pig
MD
Just a stocker as a replacement if you dont plan to go any bigger injector wise. Bob Riley/Diesel Site should be releasing their adrenaline pump shortly (hopefully)
Lilpooh
Sassamansville, PA
How are you reading the ICP psi? With analog gauge or thru OBDII?
Thru OBDII with custom tunes will net a low ICP psi.
Pizza pig
MD
depending what tunes. geahead and tsd tunes read proper psi through the port, on my truck at least they do.
