Hub Center to Fender Measurements - 7.3 on X Codes
zj96sc
I did a little searching for these measurements but most folks take them fender to ground which can be impacted by tire size so you lose any real uniformity in the numbers.
I am on a worn out set of U/As with a leveling kit, considering X codes and 350 blocks, but I'm concerned the X codes will get me more than the 350 blocks and I'll have the wrong kind of rake. 7.3L SRW 250.
I was hoping someone could get me a hub center to fender lip measurement for a 7.3 on X-codes along with the miles on the springs.
Also interested in any hub center to fender lip measurements - I'd like to build some data on what lifts/spring packs + age net you what ride height under the 7.3. I will throw up my hub center to fender lip for my setup when I get home and update this first post with all the data that gets posted up as it comes in.
zj96sc
Welp for what its worth here's what I've got so far - only able to find one clear cut hub to center measurement from fresh x-codes over on FTE, plus my numbers:
Year --- Engine --- Model ---- Config --- Springs F/R --- Miles --- Front ---- Rear
2002 --- 7.3 --- F-250 --- SCSB --- U+level/A --- 188k --- 24.75" --- 25" (me)
2003 --- 6.0 --- F-350 --- CCLB --- X/? --- 0 --- 24.5" --- 27"
