I did a little searching for these measurements but most folks take them fender to ground which can be impacted by tire size so you lose any real uniformity in the numbers.
I am on a worn out set of U/As with a leveling kit, considering X codes and 350 blocks, but I'm concerned the X codes will get me more than the 350 blocks and I'll have the wrong kind of rake. 7.3L SRW 250.
I was hoping someone could get me a hub center to fender lip measurement for a 7.3 on X-codes along with the miles on the springs.
Also interested in any hub center to fender lip measurements - I'd like to build some data on what lifts/spring packs + age net you what ride height under the 7.3. I will throw up my hub center to fender lip for my setup when I get home and update this first post with all the data that gets posted up as it comes in.
