HUGE 6.4L build project complete
dmkolb
First I want to say THANKS to Morgan Primm of Midwest Diesel & Auto who I probably got 75% of all my parts from. His before and after support is the best I have ever come across. Thanks Morgan.
This is a 6.4L build that has been going on for about 7 months now at Dynamic Diesel in Snohomish, WA. Just fired up a few days ago. We're calling it Project Street Sleeper and Diesel World will be doing a write up on it in the next few months. I'll share the build list and then some pics. Power wise I will say that Morgan was able to make 811 RWHP with a similar setup truck using the turbos I have. That truck didn't have fully ported heads, Stage 3 intake manifold, Stage 1 cam, or water/meth. We do. We're hoping to dyno May 24th and we aren't sure what it's going to make. We're guessing until we dyno but figure it'll be around the 900 RWHP mark give or take. It's just a guess though.
2009 Ford F-250 6.4L Powerstroke Diesel FX4 Crew cab
4x4 3.73 gears 35" BF Goodrich All Terrains
Engine has been professionally machined & race balanced by Action Machine Shop “Shoreline, WA”
BDS Suspension 546H 4" Lift Kit
ProComp Traction/ Latter Bars
Amsoil lubricants in everything
Amsoil Remote Oil Bypass Unit
Bullet Proof Diesel Oil Cooler System
Sinister Coolant Filter
ARP Head Studs
ATI Harmonic Balancer
River City Diesel Billet 11 blade 59mm High Pressure Turbo
River City Diesel 75mm Atmosphere Turbo
River City Diesel Exhaust Manifolds
River City Diesel Aluminum Oil Pan
Colt Cams Stage 1 Camshaft 4000 RPM .405" lift 182/196 duration
New 6.4L stock heads that have had bronze valve guides & High Rev/ High Pressure valve springs installed. Porting done by Action Machine Shop “Shoreline, WA”. Stock CFM air flow was 168 CFM. After porting we are at 200 CFM through the heads. OEM head gaskets used.
Midwest Diesel HD 0.030” over pistons, De-lipped with valve reliefs and ceramic coated
Total Seal Zero Gap Piston Rings “Middle ring only. Top and bottom rings are stock to prevent pressure building up between the Total Seal rings.”
Midwest Diesel Dual Fueler twin K-16 fuel pump kit
Midwest Diesel 30% over fuel injectors
Midwest Diesel stage 2 pushrods
Midwest Diesel stage 3 ported intake manifold
R&R Racing Billet Steel Connecting Rods w/ ARP rod bolts
Fass Titanium 150 GPH Lift Pump
Stage 2 Ported Fuel Rails
Maryland Diesel Crankcase Evac System
ATS Stage Five 5R110 transmission with billet input shaft, billet intermediate shaft, billet overdrive planet, modified pump, valve body and Raybestos clutch packs
ATS Five Star Torque Converter
ATS Billet Flex Plate
ATS High Capacity Trans Pan
Gear Head Custom tunes
MBRP 4” exhaust with Street Diesel Performance 4” downpipe, DPF Delete no cat
Banks Techni Intercooler
No-Limit Fabrication Air Intake
No-Limit Fabrication hot side pipe kit
No-Limit Fabrication cold side pipe kit
BD Turbo guard Blow Off valve
Street Diesel Performance EGR delete w/ External Waste Gate & EGR coolers removed
Snow Performance Water/ Methanol injection
DieselSite Complete 6.4L Boot Set
Turbo Blankets
dmkolb
Working out some tuning issues right now and taking it really easy for the break in. So far so good though for the most part.
Spatel23
Olive Branch, MS
very cool build and congrats.
Not too sure about that ATS trans though, they haven't really stood up in the past.
Hopefully it stays right for ya.
post some pics of the actual truck when you get a minute
bft blue oval boys
Burlington, NC
Sweet build! Really interested in how far you take those turbos. Keep us updated!
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
looks awesome! hope the trans holds out for ya....
Breaking Habits
Mapleton, Illinois
Derek,
Build looks great, sent a few parts your way for Morgy.
I have to ask.. You didn't mention anything, and pictures show otherwise...
PLEASE tell me your doing something over stock up pipes?!
Jared
dmkolb
Thanks for all the comments. We went with an ATS trans because the shop I use in an autherized ATS installer and handles warranty issues as well. So I could have gone with someone else but shipping a trans mission some where price wise would suck. main reason I didn't end up getting one from Morgan. Plus they made it to handle 1000+ HP so we'll find out. They have the 5 year 500,000 mile warranty and you no longer have to use their controller. They'll cover the labor of removal and installation as well. I'm 5 minutes from my shop so in my case I was happy to go with them.
Uppipes are stock. We did use RCD manifolds on purpose so I didn't have to mess with the uppipes. Maybe that will be a mistake but it's all ready done.
Jarod if you'd like some more info get a hold of me. I have used quite a few RCD parts. I'm excited to see what your turbos are going to do on this setup with the porting. Hopefully we will dyno at BD Dyno days on May 24th.
6.4strokin
ATS trans are junk just saying. Shoulda upgraded uppipes also
pog
psa
I might hit up bd dyno days. I'll look out for you if I go. Awesome!
dmkolb
I hear ATS trans are junk alot online. I have seen this shop install a few of some higher HP builds and they have held up fine in the last couple years. I do agree several years ago when ATS was having parts made outside the U.S. their quality sucked. They have sense moved everything to the U.S. and make it all in house. I don't want to get into a lets bash ATS conversation. This one was one of the 1st Stage 5s they have made for the 6.4L. They have made several trans for some Cummins guys making close to or over 1000 RWHP and they are holding up. I understand those transmission are completely different designs but when it comes to where they used billet parts and mods they do inside the trans it's the same type of improvements. It's designed for the power I'm making and they warranty it knowing I'm making desent power. Everything breaks when you start making big power. Hopefully mine wont but I'd rather go with an ATS than use someone elses and have to pay the labor and shipping to have it covered by a warranty when or if I broke theirs. If I destroy it I'll let everyone know. Lets wait until I actually break it before we flame it. But thanks for the vote of convidence. ;)
dmkolb
Oh someone asked about the bypass oil filter. It's from Amsoil but I'l also using a Bullet Proof oil cooler kit. It also comes with it's own large spin on oil filter that replaces the oil filter on top of the engine. We mounted the Bullet Proof oil filter behind the bumper under the driver side head light. The Amsoil bypass filter is mounted behind the front bumper center of the engine area.
