Humming noise inside
funyun
Lately I've had this wierd humming/moaning type noise coming from the truck. Its the most noticeable at an idle when the motor/exhaust isn't very loud. If I give it a little bit of throttle it kind of speeds up with the motor. Can't figure out what it is.
8luggin
mechanicsville virginia
Hmm I've got something similar nut I noticed it when I switched to the 275 tune haven't heard it raise up with throttle though
8luggin
probably not it but if you upgraded your cold side pipe check that to make sure its not rubbing/vibrating the core support i found that making a noise as well
