Hydra PHP issue
Majorpecs
this may be a dumb question, but do I need to install something on my hydra chip before I install it?
This is a regular hydra with no custom tunes. I pulled my ecm and found a banks module on it, that was there when I bought it because I didn't install it.
when I pull the bank and put on the hydra the wait to start light doesn't come on and the trunk won't crank. When I put the banks chip back on it starts right up.
Not sure if I'm missing something in the equation or what.
Gnathv
Yes, you need to install the tunes for your trucks pcm onto the hydra chip. If you have the extension connector you can do it in the truck, if not you have to pull it out again. Hydra flash is the program you use.
