Hypermax holset h2e Kit
Enslow
Baltimore County MD
Just pulled this kit off the truck to switch up the setups. This is a swamps modded h2e kit like the title says. Similar to a 38r setup. Setup comes with intake, y pipe, inner cooler pipes, oil lines,etc(whole kit). Thing worked great! There's roughly 8-10k on the setup. Turbo has ZERO shaft play and ran great with the 238/100's. Switching to a t4 468 and 300/200's setup. I can post up some pictures later this evening. $2000 shipped. Do also have some stock intake plenums for sale.
Jomax
Arizona
Would've jumped on this if I didn't sell my 99, great deal!
Enslow
Baltimore County MD
Only bad part I can see is that some of the paint on the intercooler pipes had come off. Just need to be resprayed or powder coated
StandAlone
Are their bellowed up pipes someone could buy to go along with this?
Enslow
Baltimore County MD
Will this kit go on an early 99.would I need to buy anything else?
I'm not to sure about the early 99, if anything you would have to change over one of the up pipes to obs or the drivers side header I believe. Would be a good question to check with Hypermax about
sqrlgtr
Ok I will dig around.Thanks
sqrlgtr
brandonshaver94
What kind of boost did you see with it? I really need one i just don't have studs yet and not sure if stocks will hold
Sent from my VS986 using Tapatalk
